Hi. I'm looking for sealant that has the same qualities as low modulus neutral cure silicone (ie high flexibility good adhesion to masonry) yet is paintable. Would greatly appreciate some direction on this.
Wickes do one that is general purpose adhesive and sealent. It's one of the new modified acrylics. Not cheap at over a fiver per tube. Frame sealent is much cheaper.
