Hi all,
Looking for some advice as a first time buyer.
I viewed and offered on a property a couple of weeks ago. The property is a ground floor maisonette.
The mortgage lender carried out their valuation survey of the property and have agreed the offer without any restrictions or conditions.
I also instructed a Homebuyers survey for peace of mind. This highlighted a number of concerns. Most are easily dealt with, no gas/electric certs flags as a category three etc.
However, they have also noted the gable wall has some bulging and suggesting wall tie failure. I went and took a look at the property and it appears to be at the first floor level that you can see some bulging.
The current owner has stated the building maintenance is covered "top floor cover their walls and roof, ground floor cover their walls and foundations" I am waiting for written confirmation of this.
I am going to get an additional surveyor to inspecting specifically this issue.
So my question, am I better off running a mile and starting again? I've had a root on here and other forums and prices seem to be around the £2-7k depending on the size / area of the building. I know you can buy kits to do it, but I suspect I'm better off getting this done professionally for guarantees/warranties.
Do I also need to inform my lender? Or should I only inform them once I've received the second survey? I'm guessing there's not much to be done until I know more.
I now know why my parents have only moved once. It's a headache!
Thanking you all in advance!
