Hi all,
We live in an older property that has high up wall vents in the bedrooms. Our windows are older and don't have trickle vents. However, we're getting our windows replaced and have the option to add trickle vents. My feeling is that we should just use the wall vents and not have trickle vents in the windows. I think it's either or and not both. I don't really want vents in the windows because it makes an unnecessary hole in it to allow draughts and noise through and they are typically restricted by blinds/curtains etc at night and maybe not as effective as a wall vent that is not covered up. I have to say that currently I have temporarily covered the vents so now we have no ventilation in the bedrooms and humidity overnight can typically reach 70-75% in cold weather but this is for a few hours.
Assuming this logic is reasonable has anyone converted a wall vent such as this (image attached) to have a background ventilator such as this fitted:
blaubergventilatoren.de
My reasoning being it might look more modern than a grille and also allows control of how much air you let in out and it has a filter. I may also be able to add some acoustic damping to the remaining space in the hole around the 100mm pipe. The main issue for me is the filling in of the bits of the hole not covered by the passive ventilator. It's a fair bit of effort for maybe not huge gains functionality wise to leaving the standard grille with no control of air flow..
Anyone think this would be worth doing?
Wall vents for natural supply ventilation BLAUBERG WHM 100 DK | BLAUBERG
►Wall vents for natural supply ventilation BLAUBERG WHM 100 DK◄ ★at the official BLAUBERG Ventilatoren website ☑Description ☑Characteristics ☑Photos
