wallstar combi
21 Dec 2009
Cambridgeshire
hi i have a wallstar oil combi boiler and it has started to lockout on regular basis i.e. every time i want use it :x any help would be good it also seems to have alot of air build up in the line is this normal ? i do bleed it every time it locks out but this has not made a differance it still locks out ,it is doing it about 6 times a day but when i reset it seems to be fine for a while ,it has done it b4 but for the last 3/4 weeks its been fine but now the problem is back and is worse than ever.
any help or ideas for what could be wrong would be would be gratefully appriciated .
Check any combined isolator/filter valves at the tank. Any trapped gunge could have iced up in freezing weather. Check any filter near appliance as well.
thanks will try that did not think to look there .
i did however have to reset it b4 i went to work tonight and as far as i know it has not gone off again as i would have had a call from the mrs,.
any other ideas i could try :?:
