- Joined
- 17 Oct 2015
- Messages
- 12
- Reaction score
- 1
- Country
I have just purchased a 2 level 4 bedroom detached house, built around 1990, and I would like to install a couple of RJ45 flush fitted face plates in order to neatly network my home.
Obviously, I have Wi-Fi, but for streaming video and file server applications, you can't beat a wired network
The two main locations I want to have face plates are in the living room, and the man cave.
I want to put my file server and networking gear in the attic, and run Cat5e from the router down the stud wall cavities. (There is already power in the attic)
I had an idea when I saw the location I wanted to put the living room face plate had a TV aerial socket. I thought I could tie a piece of string to this aerial cable, and pull it up into the attic then tie Cat5e to this and pull it back down.
However, when I traced the aerial cable from the attic side, it disappears down into the wall cavity at the diagonally opposite corner of the house!
I think that since I don't know the route and because of the length of the route, pulling this up would be difficult, if not impossible.
So instead, if I wanted to dangle a weighted string down from the attic, should the cavity go all the way down to the ground floor? Or will the first floor get in the way?
Are there any idiots guides on making the hole in the plaster(board?) for the metal back box?
The bigger problem I think will be the man cave.
The man cave room is actually the fourth bedroom which is actually on the first floor of an extension which also extends the kitchen on the ground floor. The problem being I have no access to the attic space above the man cave because of the eave wall of the original house.
However, there is an aerial cable from the attic that disappears through the eave, and reappears through the outside facing wall of the extended kitchen. I don't see how this could have been done other than when the extension was built.
So, I'm looking for ideas on how to proceed with the man cave.
Thanks in advance for any help!
