Ok first off i have nothing against water based products unlike many older decorators i know.
Before people try to tell me i am painting wrong i have painted probally 1000 doors in the last 6 years
OK i had a conservatory to paint, It was made out of hardwood and pre primed and undercoated by manufactorer.. The only way the will gurantee this for 6 years, the primer & undercoast is oil (solvent) based and the top coat water based dulux weathershield satinwood..
OK use synthetic brushes - mostly always do (purdy)
Now with the doors i and all other pro decorators do the cutting in bits first then and all the feats on a door then the flat parts to get the best finnish with all the lines in the right place.
So i do this with the water based satin finnish and i get near enough diffrent colours where the lines meet. I made sure it wasnt my painting by doing the middle section at the same time as the upsection making sure paint was drying at the same time! but not where brush goes up and along it looks diffrent!
I dont know the answer to this with this paint, But my answer to get a perfect job at the moment is to use NORMAL solvent based satinwood paint which i have NEVER had a problem with and finnish fine everytime.
I will be calling the dulux rep but the score with them is its never there fault
This has been a nightmare for me as i will have to drive 50miles and paint 6 doors again! The windows and frames where all the lines flow in same way look fine ! its when you have sections which go diffrent ways.. IT is not a case of needing more coats either because i tested this by giving a few doors 4/5 coats on the middle section to try to get rid of the lines but to no avail!
On a side note i have been using dulux aquatec wood paint and find it is an amazing product! also dulux qd primer undercoat (great) diamondglaze (fantastic).
Its very hard explaining to clients why the finnish looks like this. Especially when it was only guranteed that if they want a satin external finnish they need to use this paint.
OK my rant over but please people tell me where im going wrong am i using the wrong brush or what? i can take photos today of all the doors i have painted with standard solvent paint 1 - 5 years on still look perfect and this is on the coast. Now i paint 6 doors with this and they look bad.
Ideas
Ideas
