I just made a fitted cupboard with sliding doors of 18mm MDF (about 600mm wide by 2300mm high) using a Henderson top hung double track. Everything looked very good but the middle one of the 3 doors is now warping. The MDF is still untreated though it will have several coats of sealer, primer, paint etc.
I think I have clearance to reverse the door to solve the immediate issue but is this a known problem with MDF? I thought the stuff was not supposed to warp. The middle of the door has moved about 10mm in less than a week. The room is a well ventilated bedroom with little or no moisture.
Thanks for your comments.
