Yeah. Senior moment!We would know with an RCCB. It's an RCBO
not a standard multi-meter, so to repair it likely better to get a washing machine repairer to trying to DIY as the test gear costs so much.
That could be a result of poor wiring and or connectionsIs this RCB or MCB. I changed the plug's fuse and it sizzled so pulled plug straight away
Washing machines use mineral insulated heaters, which if the seal is damaged can absorb water and this results in an earth fault,
Oh no, that's rather dangerous.As Eric says the heating element is the most likely cause. Disconnect and insulate the wires going to it and see if it still trips.
Why, quite common practice.Oh no, that's rather dangerous.
I have never worked out how using two RCDs has ever complied with that? But it says "in normal operation" which is the get out clause.Every installation shall be divided into circuits, as necessary, to:
(iv) reduce the possibility of unwanted tripping of RCDs due to excessive protective conductor currents produced
by equipment in normal operation
The expense of fitting a number of 16/20A 2.5mm² or 32A 4 or 6mm² radials (other than for a specific purpose) is in my opinion crazy.who said anything about thicker cables ?
more circuits is the most sensible split in a home to minimise inconvenience (314.1.2 iirc)
Probably so post nr 23 gets the messageI don't know why it does that!
