washing machine hose blanking connector
24 Apr 2008
UK, Wittering, West Sussex
i have to disconnect a washing machine hose tomorrow - to have some flooring fitted
it does have an isolator - BUT just in case it does turn OFF completely - looking for something to either put on the hose connection at the washing machine end - or i take the hose off the isolator and connect something to that
i have various 15mm & 22mm blanking connections , i used on CH valves recently
and the blanking plates that come with rads -
I suspect i need some sort of Tap size , trying to see what the hose is in spec at screwfix was looking for
3/4" BSP (British Standard Pipe) thread male plug for the w/m end
or would the isolator connection be 3/4" BSP - so female on that i guess
hose end - which i would prefer
isolator end
is that right or what do i get tomorrow
ok thanks
i'll get
and disconnect at the W/M end and use that on the hose part
the tap worked fine and isolated the water - so i did not need the items
I purchased and used the plug anyway
and some spare hose washers - probably replace the one in there - as its about 7 years old now
thanks for the replies
