- Joined
- 26 Aug 2016
- Messages
- 6,833
- Reaction score
- 1,010
- Country
Just for your information, a vented trap isn't a restriction at all, it's basically an air break with a 40mm diameter water trap to avoid smells. The 22mm pipe will be a massive restriction, and the non return valve will be the show stopper.The only restriction would be the non-return valve - it would be much less restriction using a vented trap.
If you've 1 bar pressure you'll get excellent flow on 22mm pipe though.
