- Joined
- 27 Apr 2023
- Messages
- 1
- Reaction score
- 0
- Country
Hi all, I live in a second floor flat and am in the process of installing a new kitchen, which involves repositioning the washing machine further from the McAlpine P Trap with spigot appliance connections (the sink has a horizontal waste pipe running out the side of the flat into a vertical waste downpipe). I've had to switch the water inlet hose for a 2.5m hose which works fine, and add on a waste pipe extender to reach the waste, however it's struggling to pump out.
The issue I have is that I've ran the waste pipe down under the units and then back up to the connection on the P trap and its struggling to get rid of the water. I can hear the pump in the machine pushing, can see very little water is coming out, and the time on the washing machine is hardly moving down so it's obviously adding more time on as its not able to get rid of the water.
My question is, am I doing something wrong by putting the waste on the floor? If so, do I need to instead run it directly through the corner unit at the same height as where it exits the machine? I was told by someone that the machine (AEG) should have no problems pumping it out if it runs along the floor, but it really doesn't appear to be the case.
Also note I haven't used the U-bend connector that comes with the waste pipe extended as my thinking is that this would only be needed if I was going over a vertical stand pipe.
Thanks in advance for any problem solving tips! Diagram below from paint for reference. The trap I'm using is this and I've taken the stopper out so water can come through the applicance connection: https://www.toolstation.com/mcalpin...5cd5Eu1C-HhXuyQDUihoCOEgQAvD_BwE&gclsrc=aw.ds
