Water damaged ceiling plaster idea
12 Jul 2011
Stirlingshire
It has been around a month since the ceiling plaster came down due to water damage. Water leak in the loft has been fixed, and the ceiling has been drying for a month.
But there are still the water marks, which might suggest it is not fully dry yet? How long usually does it take to fully dry for these plaster boards? They are very old.
And there is a hole or tear on the corner of one of the plaster boards as seen in the photo. What would be best material to seal the tear or hole? I was thinking of a few options such as masking tape, plaster tape, plaster mesh or strong vinyl duck tape before putting on SBR over them.
Or would it be just better to fill it with base coat plaster, then skim over it? Thanks in advance.
Plasterboard takes a few days to dry out. Any sealer like pva or sbr will work.
You will need to fill hole first or replace plasterboard depending on damage.
Let that set then tape and skim over.
Mesh tape is fine.
Masking tape or duck tape is not the correct products
The damaged area appears to be sagging. If you do not cut it out, press it up against the joists, back into position, and secure it with screws. If it is crumbly, this will not work.
How about plaster tape? I have an old role of what looks like made of paper tape. From my memory it was for plaster tape when plaster boards are being joined, it supposed to be put on the edges? But I am not sure, if the paper tape is for the purpose, or how to put on the surface. Because it is a few year old, it might have lost adhesive at the back if there was. In that case, can normal glue be used to attach it over the damage, and the sagging bit could be pushed back into the place? Or use the mesh tape instead?
Putting on the screws on the damaged part might just crumble the bits already damaged and sagging it looks.
It looks to me like you might be better off replacing the board.
Is that a skim coat on top? It looks very thick.
It had wall paper on the old coat (brown colour - not sure what it could be). The wall paper was taken off, and I skimmed over it years ago (the white coloured coat).
It needs cutting out, re boarding and re plastering.
Andy
It is very small in size. About 10cm length, 3cm width. Not sure if re boarding for that size would be good option. Taking out the whole board and replacing with a new one would sound also waste or over the top for such a small size tear, which can be pushed in, and meshed or taped up with plaster?
The scrim tape (mesh) is stronger. With both types, it’s the plaster that holds it in place, not any adhesive.
Yes, that sounds making sense. Will just put SBR all over and wait to dry, then put some cut off mesh and tape to cover the hole with plaster undercoat. Press firm to flatten level. When dry, just skim it over flush sounds a good option.
