I need to wire a new pump into our water feature and am looking at the right way to do it.
Our socket is in the garage and the plug cable goes through the (top of the) window frame so is not easy to change. The 'path' down to the fountain is then round the edge of a shed to the fence, along the fence and down to the fountain, which is about a meter from the fence.
We have some plastic conduit attached to the fence off the ground which was used previously. Is it best to use non-armoured cable in this or to run SWA as close as I can to the garage then as close as I can to the fountain as the fountain cable is not SWA.
