What is the best way to test if the water flow rate from the cold mains is correct.
I know it should be set at 3bar mains cold supply and if it is higher, a pressure reducing valve can be fitted and adjusted to 3 bar.
My way of thinking is that if the cold water tap when turned on is splashing out of the sink then it is over pressurised at a ruff guess,(which i have been told this way should not be used as this way, even if water is splashing out of the sink means the mains is over pressurised. but how can i find out the exact flow rate, (in bar) when the cold mains is turned on at the tap.
OOps and one more question, what is cp3 used for regarding gas certs
Many thanks
Many thanks
