Water hammer on shared main
4 Apr 2010
Humberside
Anyone had success finding a cure for this. Water hammer is hard enough to find if in your own home, never mind if coming for another house on a shared main. Is about 10 houses on it.
Have look at the possibility of fitting a water hammer arrestor
Thanks yes I have ruled my house out. But finding the problem source when there is 10 houses on the row could be problematic
The area is really high pressure 10 bar. I rang the water board about the issue they said I was in a low pressure area. That I'm running at 2 bar.
OP,
How do you know that its not your house?
How did you measure the 10 Bars, what make/type of gauge?
OP,
I have turned the stop tap of and let water out still get the sound. Still get the sound in another house on the supply with my stop tap off.
I put a monument gauge on my washing machine tap.
Wonder why the pressure is so high. Water board said I was in a low pressure area when I rang
Our local W/B used to have a chap that went round with a long pole with an ear cup on the end. He used to touch it on to the external stopcock of each house along the street and listen until he found a leak. Perhaps that might help you if the problem did show up during the day. You might look suspicious at night though.
With regards to fitting a shock arrestor. I am fitting a pressure reducing valve. This will fit after my mains stop tap. If the shock is coming of the shared mains would I be best fitting the shock arrestor between my stop tap and before pressure reducing valve
It's sort of a constant humming/hammering so not like it's just trigged when an applicance is used in another house. Any ideas?
One of the houses, must be causing it, and they are sure to know they are the cause. Why not knock on each door, and ask?
Easier to fix the source, than the symptom.
