I am putting in a 9.5kW Sirrus Quickstart Undersink water heater in my kitchen. It will only serve the washing up bowl and for hand washing (no washing machine or dishwasher) but I was told to use a 9.5kw because it is attached to a mixer tap.
The cable run is about 9m from the consumer unit to the isolating switch (45A DP), and I am using 10mm cable (surface mounted on the wall behind kitchen units) with a 32A fuse. The isolating switch is about 1.5m from the water heater.
My question is … is it ok to run 6mm cable from the switch to the heater? It is getting very crowded at the back of the switch and trying to squeeze two 10mm cables (load and feed) into the available space just doesn't seem right and is VERY difficult.
