I am in the process of moving house. Our old house is currently empty and when I went to check on things the other day there had been a water leak. This was from the bathroom into the kitchen below. The main drip was coming from through/around the light fitting. This now does not work and if i switch the trip switch back on it immediately trips out again. I have left it off and not been to the house for a couple of days. Is it likely that the light fitting will need replacing or should it be ok when it dries out? Just wanting to know if I should get an electrician to look or whether it will be ok in the long run.
