I have a really weird one gents.
I have a new sink installed in my little industrial unit, using new 4 inch pipe connected to the main drain the sink joins this via a boss using 40mm pipe with P trap.
The sink is industrial and does not have an overflow.
When I discharge a sink of water from the sink it drains for a little and then stops and holds water.
I have inspected all the 40mm pipe work and its not blocked, I have also poured many litres of water down the 4" pipe and the water goes away perfectly so my problem seems to be between the sink discharge and the 4" pipe (this run is 30cm max and is not blocked).
Also I have noticed that sometimes when I empty water it goes away but at the end lots of air bubbles come up from the water.
Any Advise gents?
Any Advise gents?
