Water not heating consistently
5 Dec 2011
I own a Ariston Euro Combi A23 MFFI and when I turn the hot water tap on in the bathroom, the water heats but not to what I think is hot enough.
The tap is very slow running to gain a decent heat but as soon as you turn it just a little more, the water runs cold.
It's very difficult to obtain a decent flow that will have a hot temperature.
It's not much better with the kitchen tap either and the tap is only 7ft away from the boiler.
Any suggestions for a remedy please?
I have turned up the temperature dial and no real change in the flow/heat ratio.
Any ideas please?
You have a combi. If you look at the specifications, it will state a rise in temperature for a given quantity. This time of year, your incoming mains will be pretty close to 5 degrees, so if you have a 40 degree lift, then it will only get to 45 degrees at the tap. Your bath will have a 3/4" tap, and probably 22mm supply pipework, so it will very easy to exceed the optimum flow rate, delivering a cooler temperature than expected.
To test the performance, identify the temperature from your boiler spec book, run your tap into a measured container, and check the temperature. I suspect you will have to get used to running your bath slowly.
Thank you oilhead.
I will have a look and see what I can test with.
We have had the boiler for a fair number of years and can never remember having such a poor flow rate with a low temperature.
Now we geta bit more of the story. Do the tests, and you may find you need a new DHW heat exchanger. Irrespective of temperature, how does the hot water flow rate compare with the cold water flow rate. Easy enough to gauge with a watch and a 2 litre pop bottle.
Sorry if I didn't give enough history to the system or problem.
Is there anything else I should give oever please?
Also, is it worth giving the DHW heat exchanger a clean out as suggested with a YouTube clip?
Many thanks.
I see myself as a confident and competent DIYer, so I would like to know if I am in a position to remove the Heat Exchanger myself and clean it out or is it a job that can only be done by a gas registered engineer please?
Thanks.
Read the manufacturer's instructions.
Changing the secondary heat exchanger is not in itself a registered gas fitter only job, but if at any point you have to either disturb a gas carrying component or open the combustion chamber door (is considered part of the flue system) then it MUST be done by a competant and qualified (Gas Safe Registered) gas fitter.
Prepare to catch water dripping from the boiler, and protect all the electric parts too.
Thanks MeldewsMate.
So I feel I can do it. I presume the order to fix this situation is to:-
• Turn of the electrical source.
• Drain the system.
• Remove the DHW heat exchanger.
• Clean throughly.
• Reinstall DHW heat exchanger.
• Fill system to correct pressure.
Is there anything else I should be doing or looking out for please?
Hello.
I am waiting on my order of Spirit of Salts to be delivered (bl*ody Christmas) so I can flush out my DHW Exchanger.
I presume the metal used for the Exchanger will cope with the acidic strength SoS is?
I won't corrode and damage it please?
aluminium wouldn't, but anyway that's horrific stuff isn't that what they used for acid attacks? if you did a risk assessment you'd realise at 55 quid it's the only option to replace the thing!
Thank you for your reply. Right now £55 is alot of money. If I had that sort of money right now I would probably get an engineer to do the whole job.
I saw this excllent YouTube video showing how to clean a Exchanger with SoS......
