    Dismiss Notice
Water pressure to high for new basin tap
Discussion in 'Plumbing and Central Heating' started by Graeme, 3 Jan 2019.
  1. Graeme
    Graeme
    23 Dec 2002
    268
    Thanks Received:
    6
    Glasgow
    Country:
    After installing a new 'waterfall'' type tap onto bathroom basin, which stated on the box minimum pressure 0.2 bar, the water comes out of the tap with excessive pressure.
    Instead of coming out at 180 degrees like a standard tap, this one shoots the water out at 90 degrees so when fully turning on the cold water, it splashes large amounts of water beyond the basin & onto the floor.
    The hot water tap fully open is fine.
    My question is; would it be OK to partially close the isolation valve to the cold water tap behind the sink and would this reduce the pressure to the outlet and prevent this splashing effect when the cold tap is fully open?
    This is the tap installed;
    [​IMG]
  2. Sponsored Links
  3. blup
    blup
    5 Nov 2007
    1,510
    Thanks Received:
    257
    Country:
    I believe isolation valves are designed to be fully open or closed so anything in between might cause it to seize after a while, but it’s an option
    Blup
    • Thanks Thanks x 1
  4. ReganAndCarter
    ReganAndCarter
    13 Sep 2010
    3,374
    Thanks Received:
    353
    Police State
    Country:
    Is it a quality tap, or a cheap piece of Chinese rubbish?
    (My money's on the latter.)
  5. Graeme
    Graeme
    23 Dec 2002
    268
    Thanks Received:
    6
    Glasgow
    Country:
  6. Madrab
    Madrab
    4 Oct 2012
    7,833
    Thanks Received:
    2,200
    East Renfrewshire
    Country:
    Yes, it's ok to turn down the iso valve but it may get noisy.
    • Thanks Thanks x 1
  7. Sponsored Links
  8. Graeme
    Graeme
    23 Dec 2002
    268
    Thanks Received:
    6
    Glasgow
    Country:
    Thanks Rob. I closed the valve a little bit and that was enough to stop the over spill and there was no additional noise yet.
  9. ReganAndCarter
    ReganAndCarter
    13 Sep 2010
    3,374
    Thanks Received:
    353
    Police State
    Country:
    My mistake - expensive Chinese rubbish. ;)
    Could have got a decent Bristan waterfall that would have worked properly for around 80 quid.
    https://www.showerstoyou.co.uk/bris...MI37HF7aPS3wIV4ZXtCh2yUgHIEAYYBCABEgIfUvD_BwE
    '5 year guarantee' :ROFLMAO:
  10. Graeme
    Graeme
    23 Dec 2002
    268
    Thanks Received:
    6
    Glasgow
    Country:
    Cheers, now I know where to go after 5-years time, once the homebase guarantee expires and my £27 expensive Chinese rubbish tap fails
    • Like Like x 1
  11. Lower
    Lower
    22 Dec 2005
    1,958
    Thanks Received:
    279
    UK
    Country:
    • Like Like x 1
  12. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
