NO - 4 times the force, but exactly the same pressure (give or take any losses). That was the point I was thinking about.a say 1" surface and a 1/2" plunger is about 4x the area so 4x the pressure
As I've implied, it depends upon how one is trying to do it - 'twice the force', per se, doesn't mean a lot. As I said, it might be simple if I think about it carefully, but I have yet to do that! There is also the matter of 'reversing the process' (to turn the main valve back on) that needs to be considered - and which, again, might not be totally straightforward.edited it to be 2x as its pie r square how ever you say it ... if you have twice the surface area then you have twice the force as long as the water cant get to the reverse side off the diaphragm
By the way, I don't understand your arithmetic at all. If you're talking about a 1" diameter surface, that's a bit over 500 mm², not 80 mm².a say 1"[80sq mm] surface and a 1/2"[40sq mm] plunger ...
Yes, a spring would almost certainly be involved, but you would also have to have some mechanism (another 'hydraulic actuator'?) to open the 'vent'.you have a small return spring so when you close the 2mm hole and vent the water the spring opens the plunger
Fair enough, but I'd still like to see some sort of illustration of the totality of what you have in mind.you would have the same actuator that opens the 2mm port to start the process closes the vent port so when you close the port to stop the process it vents the chamber
