Here's a new one!
Customer called me with no hot water and no water in some WC cisterns. Kitchen tap OK.
When I got there, I found water softener (ion-exchange) resin in the pipework downstream from the water softener. It had got EVERYWHERE. Since it is made of consistent-sized small beads, it WILL flow out of the pipes so long as there's no restriction on the end and the pipe is not pointing upwards for any distance. In these cases, it just sits there as a damp mass allowing minimal water flow through.
Luckily, dismantling WC and other cistern valves and taking garden-tap non-return valves, etc. off the ends of the pipes allowed mains pressure (3 Bar) water to push the resin out. Altogether, there must have been 3 - 4 litres of the stuff in various pipes! I'm now left with two short and inaccessible pipe-runs (in floor and wall, and behind a built-in basin) that are still blocked. I've tried raising the pressure in the upstream pipework to 7 Bar (using a hydraulic test pump). All that happens then is the resin allows the (very slow) flow rate to increase a bit to dissipate the pressure but the blockage stays where it is.
I imagine that some sort of baffle plate intended to keep the resin beads inside the softener has split or otherwise broken, so the flow of water carried the resin out into the pipes.
Anyone EVER come across this problem before? (It's certainly a first for me!)
Does anyone know a reliable, non-intrusive method of removing the resin beads from pipes? I've tried extra pressure - no effect. I'm considering vibrating the pipes somehow to increase the spaces between the beads. Once the water flow gets going, the resin comes out quite easily but the problem is getting it started.
Back-stop method might be to dissolve it out - but I don't know enough about the resin to identify a good solvent that will dissolve the beads easily into a flowing liquid WITHOUT attacking any metal or plastic plumbing components. Ideas, anyone?
