TV Model is JVC AV-21QS5SP
It is a 21inch colour television NOT a flat screen.
In that case it is probably NOT just a plug. More likely to be some kind of transformer or voltage converter.The plug was a moulded one. I cut it off. Cannot get into it to see fuse.
Actually, it's 85W divided by 240v, which is 0.35 Amp approx power requirementc (less than some light bulbs) but the flex is probably rated at 5A. JVC and other TV manufacturers seem to recommend a 5A fuse in their UK instruction manualsSOOOO : 220-240V divided by 85 watts
SOOOO : 220-240V divided by 85 watts = not a 3amp but a 5amp fuse needed (which someone at the start of this dialogue kindly suggested).
You could read it again...now how do I find out if my CUT OFF 2-pin plug had such mains filtering properties ?
Written on the plug on one side is : Noise Filter 25A 250V
On the other side : HPF 2x500(squiggle)H
Was this him?:AND . . . it was a B&Q ELECTRICAL chap that I asked advice from.
