Just thought I'd check for a quick fix for my prob before I call WB.
We have no CH. When it is turned on the boiler fires up (and I presume the pump) for about 20 secs, with the green 'flame' light on. After this 20 secs, the light goes off but the pipe to the radiators is hot and you can hear the water running through the boiler.
The CH pipe remains hot (as do the spurs to the radiators). However there is no heat to the radiators. On two (of 5) upstairs radiators the pipe leading up into the radiator gets warm, but this warmth does not flow up into the radiators. There is no warmth at all on the downstairs radiators.
Pressure is fine at 2 bars and the hot water works fine (thank God!).
My guess is that the pump is broken (as I can't hear it continually) or full of air. Gravity gets the hot water to the two nearest radiators but no further. But is the hot water sent round the house by the pump too (if so it can't be broken can it?).
I have checked all radiators for air.
Any help would be greatly appreciated!
I'm really annoyed as our local plumber serviced the boiler 3 weeks ago and has either done something wrong or failed to do his job properly.
I hope it is a broken pump cos I don't want a repair bill for someone else's cock up.
Paul
Paul
