What bells and whistles do the "numpty controls" have?
Can they match this.....
■ Demand-dependent heating circuit pump and burner off control
■ Adjustment of a variable heating limit
■ Anti-seizing pump protection
■ Heating system frost protection
■ Integral diagnostic system
■ Maintenance display
■ Cylinder thermostat with priority
■ Control of solar DHW heating and central heating backup in conjunction
with the solar control module, type SM1
■ Display of the solar energy yield
■ Auxiliary function for DHW heating (short-term heating to a higher
temperature)
■ Screed drying program
■ External starting and blocking (in conjunction with extension EA1)
Will the "numpty controls" meet the stringent requirements of DIN EN 12831 for calculating the heating load?
http://www.tu-cottbus.de/LSTA/_downloads/DIN12831_SuR.pdf
That screed drying program is a nifty addition on its own. Plenty of numpties fire up the boiler on ufh systems and before you know it the screed has curled up the walls and has more cracks in it than a labour party election manifesto!
I'm sure Tony could pull something out from the back of a tv and solder on a few resistors and do all of the above but with these controllers available readily off the shelf then hardly much point.
