WEATHERPROOF IP66 SWITCH IN BATHROOM
1 Apr 2013
Manchester
Am I able to have a weatherproof IP66 outdoor 10A switch installed in my bathroom in Zone 1?
I want a 2gang switch in either zone 1 or 2, to operate a heated towel rail and an extractor fan.
I've ruled out a sensor switch which sits under tiles as I am having Showerwall (which is not easy to take down once up) and I don't want a pull switch.
Any ideas?
April fools aside, IP66 is actually tougher to meet than IP68 according to a lighting designer friend of mine. IP66 means pressurised jets, and the dynamic pressure exceeds the static pressure that they test to for IP68. A wheeze when products failed IP66 tests was to submit them for IP68 tests - they don't check all the IP6x up to 8 when certifying... :shock:
I was assuming it was SELV, and quite forgot the date..... :roll:
I know...ASS U ME.....
You can use a regular lightswitch in a bathroom as long as it is 600mm away from the boundary of zone 1 (the edge of a bath tub or shower) for obvious reasons. You don't need a waterproof lightswitch in a bathroom, it just needs to be far enough away from zone 1 is all. By the way, wouldn't it be better to put a heated towel rail on a switched thermostat???
