OK but what sort of UFH, water or electric mat? If cable, have you laid an SLC over to form the tile base? I may have missed all this from any previous thread, not sure but it’s always best to stick with your original thread with continuing questions for continuity as folk won’t necessarily know about previous threads unless they check your post profile which takes up a lot of time.I want flex as i have under floor heating.
You’ve obviously done your homework!The tiles are matt finish but must be sealed already as i have tried ketchup, red wine, dirt etc and it all sits on top and wipes straight off.
No, no, no it doesn’t work like that; it’s essential that floor tiles are fully supported (ideally 100%) or they could crack under load. A thick, solid bed trowel (20mm round notches, 10mm deep, at 28mm centres) will give an average adhesive depth of 3-4mm when bedded on a perfectly flat floor but you have to allow a margin to ensure adequate adhesive depth as very few floors are perfectly flat. This may be marginal with larger format tiles (over around 300mm) on anything other than a perfectly flat/even floor so the notch depth is increased by 3mm to make allowance & ensure you get close to the ideal 100% coverage.So 13mm depth on adhesive?
Is that a standard trowel size if i look top buy one?
Like these?
http://www.screwfix.com/p/ragni-not...=1132939#product_additional_details_container
http://www.toollineuk.com/product.php/site/froogle/sn/VIT102958[/QUOTE]
The links don’t specify how deep the notch is but my guess is they are a standard thick, solid bed trowels with notches @ 10mm deep. That may well be enough on a nice flat floor & I often use my standard thick bed trowel on all but the very largest (paving slab) tiles but given what I’ve said above & without seeing your floor, I would recommend going to a large format trowel.
As stated, I generally use only BAL but it’s not cheap; I have limited experience with Webber but other pro tilers speak of it highly.Weber looks too cheap compared to others. Or are others too dear compared to Weber
Ok that now makes sense.HI, it is wet under floor heating.
The trowel is initially used fairly flat to lay down a bed of adhesive to a consistent thickness over what ever area your capable of working on & but usually no more than one sq/m at a time, especially with Rapidset which must be used in around 40 minutes. Being as plasterer also, my preference is to use a hawk rather than direct from the mixing bucket & lay it on much like plaster. Then hold the towel at a 45 degree angle & draw it across the adhesive bed to form straight ribs at right angles to the tile; remove the excess as you go but don’t put it back into the bucket, reuse it straight away. Using the correct size trowel will give the right depth ribs of adhesive to give 100% coverage under the tile but with experience, you can of course vary the angle of the trowel to give a smaller or greater depth to the adhesive bed depending on tile size & how flat the floor is; the important thing is to get that 100% coverage underneath the tiles or they can crack under impact or load.Can you explain the trowel use, i.e when applying should you trowel at say 45% rather than vertical if that makes sense?
Your paying for quality, consistency, reliability & excellent technical backup & for me the range of their products I use is 100% predictable which is why I rarely use anything else but there are other brands equally as good. At the end of the day the additional cost of decent adhesive & grout is small compared the cost of some tiles & a catastrophic tile failure.I know Bal is probably the best name but are we paying for that?
You can use silicone or a threshold cover strip but a proprietary expansion joint will look much better; http://www.wallsandfloors.co.uk/range/Aluminium-Heavy-Duty-Movement-Joints/I was thinking of expansion joints at doors.
Would a silicon joint be the best idea with tiles stopping both sides of doors and the silicon rather than grout applied, or can aluminium strips be used?
That’s fine but don’t grout the gap between the tile & the wall.I can leave tiles away from walls as i will be skirting after i have tiled.
