wedi board
7 Jul 2022
Hi all,
I need a bit of advice on the use of wedi boards as I've never used the stuff but it looks a great product to create my wet room with, the fitting of the boards and sealing seems straight forward my issue is when it comes to fitting towel rails etc once the tiles are on. Can i just drill into this fit a raw plug as you would on plaster board walls? personal i don't think that would hold very well and it would compromise sealing, or do i have to insert wood into the wedi board where i would like to fit things so there is something to screw into which would make more sense but how do i fit things at a later date if i decided i wanted say a shelf putting up and there was no insert where i wanted to put it.
Wedi do, or you can use a suitable reinforcement board. Your cut out the precise depth of the area with a router then attach board with 610. Reinforcing tape over afterwards.
