Hi all, hope you can help.
I had a new bathroom put in last year and the walk in shower has a WEDI Tray (that's what the builder called it).
We frequently get a bad egg smell in that bathroom if the shower hasn't been used for a couple of days (it isn't the main bathroom) and the smell is coming from the drain in the shower.
I took the metal cover off and there was a fair amount of hair and smell so I've given it s clean. However, I'm unsure about the plastic but that fits inside. I assume it operates a bit like a u-bend in that water collects inside it then runs under the lip (it's like a cup inside a cup) and then into the drain.
But there's a fairly big gap all around the plastic bit, which just leads directly to the open drain. I'm assuming the smell is coming from the drain as it is essentially open to the air. Should there be some sort of seal or something to close the gap that can be seen in the photo?
Cheers
Cheers
