Weep holes needed?
3 Feb 2016
I am planning to build a detached outbuilding with partial filled cavity walls and blocks on the inner and outer skin. The external blocks will be rendered after. I have read a lot about weep holes but they only seems to be mentioned on cavity walls with brick on the outer skin, which are exposed (not covered by render).
Am I right to assume that block external walls which are covered in render will not need weep holes?
Subjective depending on building control opinion last time I came across this. The logic being if it’s rendered it’s more waterproof so less likely to need them. Also depends on what purpose the cavity tray is serving
If you have a DPC, (which you naturally should do), then the rendering can't go down to ground level without bridging the DPC.
When people talk of weep holes, most imagine a small round tube. But you can now get slotted weep holes which nestle between the vertical mortar joints and are quite unobtrusive.
