Weep vents positioning above a steel lintel
12 Feb 2026
During periods of wind driven rain I experience water ingress at the corner of a large window, which has a steel lintel above. The previous house owners' carried out major modifications including the enlarged window replacement. From the outside I can't tell whether the steel lintel is simple angle bar or catnic.
Given the water ingress, I do wonder whether a cavity tray was fitted above the lintel and if so, whether stop ends were fitted. Could stop ends be retro fitted or would it require the whole lot to be opened up and start again with a cavity tray?
In the photograph (taken some eight hours after driven rain) you will see that the weep vents are set into the blocks some 2 to 3 inches above the steel lintel, and above a fillet of Fyfestone block. Are these weep vents in the right place or should they be directly on top of the lintel base plate to work effectively? Will it be possible to fit new weep vents lower down without damaging any cavity tray that may be fitted? If so, I'm hoping that the new weep vents will do their job and possibly prevent the need for cavity tray intervention.
Any advice would be greatly appreciated.
I'm not a professional builder but it looks to me like you have a Catnic lintel above the window, which is, as far as I know, what you would need to build the outer skin on. That is how we did ours and the cavity tray went from the top of the catic and under the bottom of the outer skin. There were no weep holes or end stops installed with any water ingress simply running off ends of the tray and down the cavity. The darkend mortar above the lintel suggests to me that water is collecting on top of any cavity tray or the lintel itself and seeping out through the outer skin. I would suspect that the ends may be obstructed, perhaps by spilled mortar during construction. If you are getting water ingress across the cavity into the inner skin then it could be by capiliary action under the lintel. Personally I would seal between the top of the window frame and what appears to be a lintel with silicon as a first step before doing anything more drastic.
The weep vent height may be ok if there’s a cavity tray at that height, but wrong if they’re relying on the (cavity) lintel as a tray. Exploratory hole might be a good bet, might be able to get a camera in etc.
That lintel does not appear to have a bearing on the external leaf, and if so, yes water can run down the opening reveals.
Thanks for your replies and thoughts guys. With those thoughts and comments in mind, I've had a good close up look.
Woody, you're absolutely right, the steel lintel stops about 8mm short of the corner blocks (reveal?) at each end.
How can the lintel support if it's not bearing on the leaf? Would this meet building control? What to do to improve the situation?
Did the opening get widened? Looks like the blocks have been cut (although may just be the photo) and guess they just left the old lintel in situ and cracked on fitting a new window?
Can’t see an easy fix other than propping, removal of some of the blocks, fitting new cavity lintel with tray etc…
Hi 23vc.
Old pictures I've found show the opening was more than doubled and I do wonder if the height was reduced by the thickness of that cut course for some reason (possibly ordered wrong window size)?
That steel looks a bit thick for a lintel, so may be a steel with a welded angle.
I suspect your answer to the lintel and the water penetration will need those blocks at the bearing to be removed to see what's going on.
That work should have required building regulation approval.
I've just measured the steel, it's 10mm thick, Woody.
The modifications had a building warrant and certificate of completion ...
