Hi all,
Thank you for reading this. I have applied for a build over agreement with Welsh Water and have just had a sewer trace performed. We propose to build near, but not over the public sewer at the rear of the property. As you can see from the attached plan that I've drawn post sewer trace, I'd like to build right up to one of the inspection chambers at the rear. The proposed foundations sit much further away and are all 580mm-1500mm from the sewer line.
I had initially requested that WW consider my proposal to decommission this manhole to allow us to build right up to where it currently sits. We have another chamber accessible on the same run, and our neighbours' to the left hand side of the sketch is also accessible and within 3 metres of our boundary. I am now wondering whether we could simplify things and propose to keep the manhole where is it, but still build right up to it.
- Has managed to get a water authority to give permission for the extension to go right up to the inspection chamber, whilst the foundations remain a good distance away? It will still be accessible from the outside of the property and would only ever pose a threat to us should it over flow.
- Does anyone have any advice for me in my discussions with Welsh Water?
I look forward to your comments,
Many thanks
A
Many thanks
A
