Hi all,
New to forum - was unsure whether to post here or in flooring so hope I made the right call.
Would welcome advice re the following: have bought a terrace with a through lounge/dining room and there is evidence of wet rot to the floor joists at each end of the room and a need for re-doing the DPC. Have had two widely differing quotes and sets of advice re the flooring in particular. 1) replace entire floor in one go as if there is damp at each end of the room that makes the most sense 2) replace the rotten sections only up to the - is it called the sub wall? (a wall that runs across the division of each room) and treat the remaining healthy flooring with a fungicide spray.
Am wondering a few things here:
1) which makes most sense (the second option seems credible to me)
2) I have gone to professional damp companies so far but a friend recommended a carpenter who can do this and buy the relevant treatments as well - is there a reason to go with one option over the other? I was swayed initially by the 30yr damp guarantee for the works that the damp companies provide but the carpenter won't be able to I guess, but I am not sure if I even really need such a guarantee? Is it of any value for resale or anything do you think? Surely if the work is done to a good standard and the necessary treatment applied by a chippy that is enough?
3) if I use a damp company would you consider it necessary to use a PCA registered one or not?
I can't move into the property until the floor is done and there's such a financial commitment to it and range of costs I'd really appreciate your advice. Also, if done DIY/by chippy are there products that you recommend for the spray treatment of the good floor and for protecting the ends of the replacement joists. Other than that I simply assume it is enough to ensure replacement with treated wood?
Hope that makes some sense
Have tried a read of forum in other threads for advice so far but would really value some up to date advice on this specifically.
Thanks in advance
Thanks in advance
