Yeah, thanks, I was going to get a plate for the bottom switch. However, the isolation switch at the top was not attached to anything when I removed everything - it was just held in place thanks to the tension on the cabling. Not sure how I can secure this really as there was nothing behind it to fix it to.
That is odd. It is also a tad worrying. It means it might be difficult to remove the faceplate to feed the backplace behind. It might be advisable to post the question in the electrics forum.
Personally, I would cut a new hole higher up and use a proper plasterboard/dry lining box but that will require you isolate the cable and feed it into the back of the new box and reconnect the fan isolator.
Again, I will defer to others, sorry.
