What do you call the sleeve that's fitted to plastic pipe?
11 Apr 2006
Berkshire
I need to fit a 22mm compression elbow to a 3/4" (21.3mm outside diameter) black plastic mains pipe.
I have some 3/4" olives to suit the imperial pipe so that I can use a 22mm compression fitting, but where can I buy the sleeve to prevent the pipe collapsing/deforming as the fitting's tightened? Is it actually called a sleeve?
Gary
Plumbers Merchant, their called pipe inserts.
Bring a piece of pipe with you to match up the insert.
Andy
Isolation valves sometimes leak on the centre turn slot, use the lever valve.
It will be a lot easier to turn off and will be full bore.
Andy
