What form of heating should I install
  • Thread starter Thread starter Bodd
  • Start date Start date
Heat of any type are expensive to install. Spend the heat pump money on insulation and glazing and fits a cheap oil boiler. If you get decent U values on the house, ten electric my be OK.
Insulation is the key in exposed country areas.
Including all your various user names, this is the most sensible advice I've seen you give on a forum.
I only have one. Stop listening to the jobbing plumbers.
I always give sensible advice.
Thanks all for advice.
But after having a vewing of anothe rhouse on same street I have discoverd that the street does have Gas.
The Question is now do I get the gas connected and how much would that be compared with say ground source.
Cheers fellas
Bod
Cheers fellas
Bod
Probably much cheaper. I had a new connection around three years ago at a cost of £600.
Cheers fellas
Bod
Thanks Mathew was thinking in the thousands
Cheers fellas
Bod
Gas CH is the one most likely to add value to your house and with lower running costs might even recoup the cost of installation fairly quickly.
Cheers fellas
Bod
Ground soucre seems a good idea. But Gas C/H I'll fit myself and will obviously be alot cheaper.
Its a west facing garden so I may be tempted to try my hand a solar in the future
