What skilled worker can you get to come to your house and work nearly 3 hours for £55 these days?
Not me.
I’ve not long replaced it!
That’s what I thought. A fully fitted out dog wash van too. Maybe she spends a bit more time at first to get to know the dog? Just spoke to my mum, she has a different mobile groomer that comes to her and she only takes 45 minutes and charges £45. Mind you, my mum has a dog the size of a rabbit! Her groomer wouldn’t do ours as she says she has a bad back and can only do small dogs!£55 for three hours and a van + everything else to pay for, you gotta wonder what she must actually be earning after all that.
Pah. Mrs Mottie called in there yesterday and the heating wasn’t on. Useless brother is getting his useless plumber mate to go round and fix it but can’t go till Monday as he's away till then. Mrs Mottie was worried that the pipes are going to freeze and burst so we've just had a 2 hour round trip to give the 3 port valve another whack! While I was there I decided to turn off the water. Two stop cocks under the sink, both seized and when I freed them off, neither of them turned the water off so I turned it off in the street. At least Mrs Mottie won’t be fretting all night!Mrs Mottie and her sister are worrying about the cold spell coming up and the possibility of freezing pipes/damp in their mums vacant house. They tried putting the heating on but it wasn’t coming on so I went round to investigate. Useless brother wasn’t going round to help so I had to step in. Standard heat only boiler, vented system with a hot water cylinder, 3 port motorised valve. Y plan I believe. Been switched off for a few months. Hot water was coming on but not the heating. Thinking back to the problem I had with our system, I wondered if it was the motorised valve sticking. Tried powering off the system then back on a few times but no luck. That would work with mine when mine had been off for a week or so. Next attempt, give the three port valve a couple of whacks. That did the trick. Turned it off and on a few times and it was working 100%. Set the timer and left it to come on a couple of times a day at a low temperature - 13°. Job done!
The lever is as stiff as f*ck Andy. I’m wondering whether it could be the valve and not the head. I’ll let his mate sort it out.Tie the lever on the 3 port valve open with an elastic band.
Andy
Up in Lancs to help parents in law to clear out their static. They've decided it's too much to pay every year (£5400) for the reduced use it's getting now.
Plus, the site has changed hands a couple of times since they first moved onto it. Each time, charges have been increased massively.
IDK how these places get away with charging what they do.
Put your 'van on someone else's land and you open yourself up to all sorts of pumped up charges.
