Its an old picture now (the tiler who's been in is doing a blinding job!) but I wondered what the flooring is called thats in my bathroom. Is it just floor board? Chip board? It doesn't seem to stain or swell when water is spilt on it so I'm not sure, you can tell I'm pretty gash at this DIY thing....
Anyway, I'm going to be putting down rubber floor tiles. I came to that conclusion as I like the look of them they will hopefully allow for a bit more flex than a tiled floor. My problem is though that the current floor isn't entirely level. It seems to slope from the middle down at each end. Is there something I can use to level it off? I am going to put 6mm ply on top of it and then the 3mm tiles but would like it a bit more level first??
I know the obvious answer will be to take the floor up straighten up the joints and replace it with plywood in similar thickness but I wondered if there are any other options.
