What is needed
1 May 2008
Sussex
Ok, here we go....
I currently have a single socket in my lounge and I would like to make it a double socket for convenience.
Is this fairly straight forward to do, and if so how do you do it?
I know this is probably a very stupid and easy question.
I have looked up the adapters your talking about - yes these would work but we want to change all our sockets to a brushed metal finish. cant see the adapters with this finish.
Is the current socket flush or surface mounted ?
Flush-
Pull fuse at CU
Check circuit dead
Remove socket
Dig out back box
Chop wall to accomodate double box
Use grommets and set new box (and fix it with a screw!)
Replaster / fill gaps around box
Terminate new socket
Test
Surface-
Pull fuse at CU
Check circuit dead
Remove socket
Remove box
Provide new double back box
Test
