What on earth are you talking about?I'm not disputing you are right in this case, but incorrect as the blanket statement this was presented as
It wasn't a "blanket statement", it was specifically in response to your observation "Plastic I have little idea if it's reusable right now, it's only a couple of years old though."
That your plastic CU is only a couple of years old is irrelevant.
Your time may be. Repeat visits and reinspections by Building Control after failing the first may not be.For you, maybe. My time is free.
Indeed it is not. Which is why my reply to "How do any of us know anything?" had nothing to do with philosophy and everything to do with the context of this thread, i.e. the technical knowledge and practical experience necessary to carry out a particular task.This isn't the time or the place for philosophy but I would dispute that first part.
It isn't. But I bet there is more involved than you think there is. You thought, for example, that you could just re-use the existing CU, and didn't even think to ask if you could do that, all you thought you needed to know was what information to provide to Building Control.Agreed it is isn't always a sensible idea, but basic electrics and electrical safety is hardly rocket science.
You ought to find a bit of time for the "philosophy" of unknown unknowns, and consider whether there might be things that you don't know but won't think to ask about because you simply have no idea they even exist.
You did not talk about perceived difficulty, what you said was "The difficulty if a task is proportional to ones own experience and confidence."You miss the point, I was referring to the perceived difficulty of a task. Confidence is most definitely a factor there.
Faulty perceptions can be just as misleading as misplaced confidence. In fact the two can be intimately related.
Notch7 appears to be introducing the issue of you getting an electrician to "sign it off", which is not the case. He is right in what he said wrt that, but I don't know why he brought it up.So why do the council offer this route? It must be possible or they wouldn't offer it.
We hadn't seen that detailed wording before, and it does read as if they will do whatever I&T they feel is required to verify that your work complies with Part P. But they would not have been the first council to have a policy of charging extra for DIY electrical work and not actually doing anything in return. Yes, really.Their building regs charges document states: "Charges assume that any related domestic electrical works are to be undertaken and self-certified by a suitably qualified person and notified to the local authority through a competent person scheme (such as NICEIC Domestic Installer). Where such work is to be undertaken and is NOT going through a competent persons scheme provider an additional charge applies to cover the cost of electrical inspections and testing."
Then in the table of charges: "Domestic Electrical works not carried out under the Competent Persons Scheme" with a basis of charge as "Any other controllable electrical work" and a charge of £269.
If that doesn't mean they will inspect and test DIY work for £269 then I'm going to have to write to them strongly suggesting all council staff receive verbal reasoning training. But as has been said, ultimately I'll have to check with them.
They ought not to need anything beyond "all electrical installation work will comply with BS 7671".The original question was what sort of info they would require up front!
But that can be something else for you to ask them.
