What you have is a rad vent plug that is leaking slightly. Turn rad off at both valves and remove the plug, being careful to catch the little water that may come out. Clean and remake the joint using a new o ring / or washer, or just wrap some ptfe round the thread and screw it back in.
Thanks for your help 45years. To turn it off do I just turn the trv to blue and turn the other end. Where would I get the o ring or washer from plump world / screwfix?.
