breezer said:that is easy for you say, what air does it separate? is it a bit like an auto airvent (just curious)
but what i really wonder is what is the locking nut that is on the pipe from?
bobonacus said:that nut is from a valve in the pipe I took out to see if it was ok
bobonacus said:I can't seem to trace where the pipe labeled feed for boiler comes from!!
doitall said:bobonacus said:I can't seem to trace where the pipe labeled feed for boiler comes from!!
The pipe labeled feed from main header tank, is there a tank or not, and not the tank feeding the cylinder
doitall said:bobonacus said:that nut is from a valve in the pipe I took out to see if it was ok
Right that confirms it, when filled the water will flood out that pipe thats now open.
The system has been converted to a sealed system, there must be an expansion vessel and safety relief valve or the system is dangerous.
doitall said:Lets start again.
The pipe you took the valve off is/was the cold feed to the boiler, the pipe next to it is/was the expansion pipe.
Where they go or do is important, so where does the cold feed go and where does the expansion pipe go.
Are you saying it connects to the mains cold water or to the main starage tank
