Indeed. As we've often discussed, I'm sure that there is an awful lot of 'leeway' built into cable CCCs we use. One could therefore probably 'get away with' exceeding the CCC of a cable by 100% or more without any problems. However, we don't (or at least shouldn't!) use that as an excuse for using a cable with too low a 'rated' CCC. Similarly with connectors ... as I wrote, I imagine that one could greatly exceed the 'rating' without any problems - but, again we shouldn't really do that.Having seen a 10.5kW shower circuit wired in 2.5 run quite happily for 2 years until the switch finally burnt out (could happen to even a correctly wired 6/ 10mm² circuit), I am inclined to think that cables, connectors etcetera have a lot of leeway engineered into them.
Kind Regards, John
