Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
I would like to round off the edge of a desk I built. What round-off router cutter (1/2" shank) diameter would you recommend for this job? Would this router cutter do the job?
TIA.
I would like to round off the edge of a desk I built. What round-off router cutter diameter would you recommend for this job? Would this router cutter do the job?
TIA.
It will, but recommending using a climb cut on someone asking novice questions about using a hand held router is IMO not a good idea. Climb cuts can be hazardous and must be used with extreme caution.
Personally, for a 3mm round, I'd use a low angle block plane and sandpaper
