What screws for wallplate?
12 Mar 2010
London
What sort of screws should I use to hold a wallplate onto 3.6N Celcon blocks and at what distance intervals?
2" 8's or metric equivalent thereof will be fine every 18".
You don't screw wall plates down - they can still lift .. and are especially crap in aerated blocks
Strap down every 2m with 1m long straps
You avin a larf....! :eek:
Considering most wall plates are 3" thick what would be the point.
As Woodstock has stated there is no point fixing to the top course as it will lift off the bed.
However, there is nowt wrong with temporarily fixing it down whilst setting out the roof. We often do this because fitting the straps prematurely can create conflict with joist and rafter seatings.
Use 100mm 6's Or 4" 12's in old money.
Not at all noseall. I assumed the OP was enquiring about screwing the strap to the face of the masonry (to which my original reply still stands), although re-reading his post it appears he wants to fix through the top of the wall plate into the top of the block. As you say, this would require a min 100mm fixing, although it is not the usual fixing detail.
The OP might want to fix a plate against a wall to support the high end of a lean-to roof.
Indeed he might or even at the low end for the ceiling joists.
When fixing any timber that is in excess of 50mm thick i would always recommend 4" 12's. Again, it makes sense to use screws initially so that they don't interferes with the joist or rafter settings, however in order to satisfy B.C. you must then pop a few sleeve anchor bolts between the rafters, just for show of course! ;)
It's for a flat foor for a detached garage
Your comment - just for show of course. Living in built up suburbia, I'd be amazed if the roof lifted off in high winds. Are the straps really necessary (no BC on this garage)?
I'm probably going to put the bent straps on the outside only which will be rendered over anyway, but I don't fancy seeing them internally on the bare blockwork
