hi,could anyone tell me the size of cable needed to wire in the reciever unit for a wireless programable thermostat please.it will be wired directly into the boiler but would like to know what size wire is needed.thanks
thanks,i thought either 1.0 mm or 1.5 mm would be ok.just wondered, because the supply to the spur for the boiler looks like 1.0 or 1.5 mm but then from the spur to the boiler they have used 2.5mm... is this ok.thanks
