Why 1.5mm, 1mm would likely be adequate and easier.
I'll assume you mean oval plastic conduit, as that's what I always use and find, in which case 3 x 1.5mm would go, but it may be rather tight.
Best / worst I've experienced was 4x 1mm t+e in a 20mm oval conduit. Sadly the installer had used crampets and squashed it, so nothing would move when I needed to change one.
I always fit 1 if there are more than 2 cables, makes things easier if a change is needed down the line....
