What size joints for Indian stone?
5 Dec 2012
Is there a typical size grout joint used for Indian stone paving? 10mm or 15mm? Cheers
If they're varying sizes then stick to whatever is needed to make up the smaller ones to the size of the bigger ones. Carefully align two 300mm ones next to a 600mm one, you'll see the intended joint size between the two. Stick to this then everything will be consistent and look right.
