What size pipe is this please?
An M6 nut or bolt is 10mm across the flats.The 10mm spanner that fits it will say 10mm..not,use this on M6 bolts, etc etc..
Vernier gauge or failing that, an open ended spanner - try a 10mm and 15mm.
Your fault Motman....see what you have started.!..why not suggest measuring the pipe with a laser and measuring the time light takes to cross the pipe,or use soundwaves etc etc...might be more up the OP's street.
10mm!...across flats..not use on M6... etc etc!!.Stick that on the ruddy pipe..if its a snug fit.. Sorted
As per title what size is this pipe that is fixed to the rad valve please, as I need to buy some form of stop caps for It as.
https://ibb.co/cxLUjo
Cut a bit off and take it to a local plumbers merchant and ask for two stop ends. Ideally go in on a Saturday 10 mins b4 they close. They like that.
A little history behind this - my neighbour (who has learning difficulties) called me in a flap yesterday as water was pouring from the radiator on to her kitchen floor. I whizzed round and turned her water off and drained the system and then took photo of pipe, and then asked question here. To be honest I was just expecting a quick answer from the 'experts' not war and peace and a UN debate. That said I removed the radiator replaced it as well as the valves and all is working fine and no drips - The pipe size was indeed 10mm. Thank you to those who contributed.
Seems to have kept you busy,this forum,contribute more often!
