I need to lay 6mm ply and need an electric stapler able to fire 22mm DP staples. Which would the professionals recommend ? (and I don't mean bodie and doyle)
many thanks, George
It's about five 8x4 sheets but I will be doing other rooms at a later time. I have no compressor. Do the professionals use air ?
btw, it's in preparation for lvt and the sub floor is floorboards.
Thanks daz, looks like you may have saved me some money.
I also have an adjacent concrete area that will need to be self levelled to the ply, would you put anything between the two ? or is it ok to run the self levelling right up to the ply ?
